Palm Treo 700P LCD Replacement
    1. Palm Treo 700P LCD Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Palm Treo 700P LCD Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Palm Treo 700P LCD Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Press the button located just above the Sprint™ logo and then slide the cover down.
    2. Palm Treo 700P LCD Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Palm Treo 700P LCD Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the small notch on the left hand side of the phone to remove the battery.
    1. Palm Treo 700P LCD Replacement, Back Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the stylus from the phone.
    2. Palm Treo 700P LCD Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • After removing the battery and stylus, unscrew the 5 Torx screws (using a T-5 Torx screw driver)
    3. Palm Treo 700P LCD Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the spudger, remove the small rubberized patch under the antenna.
    4. Palm Treo 700P LCD Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unscrew the last two screws using the previous screw driver.
    5. Palm Treo 700P LCD Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Palm Treo 700P LCD Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using the plastic opening tool, gently separate the back case from the phone body.
    1. Palm Treo 700P LCD Replacement, Motherboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Palm Treo 700P LCD Replacement, Motherboard: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Palm Treo 700P LCD Replacement, Motherboard: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Using a plastic opening tool, gently edge your way between the back and border case (Picture 2) until they are completely separated (Picture 3).
    2. Palm Treo 700P LCD Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Palm Treo 700P LCD Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Palm Treo 700P LCD Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the antenna chip by unscrewing the two screws with Torx T-5 screwdriver (Picture 1).
      • Once unscrewed, gently detach the antenna chip with your hands (Picture 2).
    3. Palm Treo 700P LCD Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Palm Treo 700P LCD Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the plastic opening tool to unlock the tab holding the keyboard connection (Picture 1).
      • Once the keyboard connection is detached, use your hands to gently separate the motherboard from the back panel (Picture 2).
    4. Palm Treo 700P LCD Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Palm Treo 700P LCD Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Palm Treo 700P LCD Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • To completely detach the motherboard from the back panel, use the plastic opening tool to unlock the LCD connection from the motherboard (Picture 2).
      • Once the LCD connection is unlocked, the motherboard should now be completely detached from the back panel, keyboard, and LCD (Picture 3).
    1. Palm Treo 700P LCD Replacement, LCD: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Once the motherboard is removed, the LCD should be resting on the front case of the phone.
Lucas
crwdns2935283:004/17/12crwdne2935283:0
26 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 12-37, Regan Spring 2012 crwdns2935289:0Cal Poly, Team 12-37, Regan Spring 2012crwdne2935289:0
CPSU-REGAN-S12S12G37
crwdns2935297:084crwdne2935297:0
crwdns2942667:0crwdne2942667:0 1,184
