Press the button located just above the Sprint™ logo and then slide the cover down.
Use the small notch on the left hand side of the phone to remove the battery.
Remove the stylus from the phone.
After removing the battery and stylus, unscrew the 5 Torx screws (using a T-5 Torx screw driver)
Using the spudger, remove the small rubberized patch under the antenna.
Unscrew the last two screws using the previous screw driver.
Using the plastic opening tool, gently separate the back case from the phone body.
