Palm Treo 700P Antenna Replacement
  1. Palm Treo 700P Antenna Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Palm Treo 700P Antenna Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Palm Treo 700P Antenna Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press the button located just above the Sprint™ logo and then slide the cover down.
  2. Palm Treo 700P Antenna Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Palm Treo 700P Antenna Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the small notch on the left hand side of the phone to remove the battery.
  3. Palm Treo 700P Antenna Replacement, Antenna: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the stylus from the phone.
  4. Palm Treo 700P Antenna Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing the battery and stylus, unscrew the 5 Torx screws using a T-5 Torx screw driver.
  5. Palm Treo 700P Antenna Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the spudger, remove the small rubberized patch under the antenna.
  6. Palm Treo 700P Antenna Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the last two screws using the same T-5 Torx screw driver.
  7. Palm Treo 700P Antenna Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the plastic opening tool, carefully pry open the back case to loosen the antenna.
  8. Palm Treo 700P Antenna Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The antenna will now be loose, gently pull the antenna out of the phone.
John Rainier Solanzo
crwdns2935283:004/17/12crwdne2935283:0
7 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 12-37, Regan Spring 2012 crwdns2935289:0Cal Poly, Team 12-37, Regan Spring 2012crwdne2935289:0
CPSU-REGAN-S12S12G37
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 856
