Replace the speaker
On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
Use the T6 Torx Screwdriver to remove all 4 screws.
Using a plastic opening tool, carefully separate the front and back cases.
Using the spudger, pull the speaker straight up.
Gently pull the rubber coating off of the speaker.
