Palm Treo 600 Screen Replacement
    1. Palm Treo 600 Screen Replacement, Back Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
    2. Palm Treo 600 Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Palm Treo 600 Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the T6 Torx Screwdriver to remove all 4 screws.
      • You have to first remove the Stylus to access the 4th screw.
    3. Palm Treo 600 Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Palm Treo 600 Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using a plastic opening tool, carefully separate the front and back cases.
      • Note: The antenna will detach from the phone.
    1. Palm Treo 600 Screen Replacement, Front Case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Palm Treo 600 Screen Replacement, Front Case: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using a T6 Torx Screwdriver, remove the two screws.
      • The motherboard will now be loose from the front case.
    1. Palm Treo 600 Screen Replacement, Screen: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • The screen is connected to the phone with an orange data cable.
      • Slide the spudger as close to the connection as possible.
      • Gently pull the spudger up and the cable should come out of the socket.
    2. Palm Treo 600 Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Palm Treo 600 Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Once the cable is unplugged, you can remove the screen from the body.
Clement Poisson
crwdns2935283:001/26/10crwdne2935283:0
24 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 13-23, Maness Winter 2010 crwdns2935289:0Cal Poly, Team 13-23, Maness Winter 2010crwdne2935289:0
CPSU-MANESS-W10S13G23
crwdns2935297:096crwdne2935297:0
crwdns2942667:0crwdne2942667:0 2,534
