Palm Treo 600 Battery Replacement
    1. Palm Treo 600 Battery Replacement, Back Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
    2. Palm Treo 600 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Palm Treo 600 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the T6 Torx Screwdriver to remove all 4 screws.
      • You have to first remove the Stylus to access the 4th screw.
    3. Palm Treo 600 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Palm Treo 600 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using a plastic opening tool, carefully separate the front and back cases.
      • Note: The antenna will detach from the phone.
    1. Palm Treo 600 Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Palm Treo 600 Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using metal tweezers, unplug small white plug.
      • Pulling the white plug will disconnect the battery. Make sure the phone is off before you do this step.
    2. Palm Treo 600 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slide the flat side of the spudger under the battery and gently dislodge the battery by lifting the spudger up.
      • The battery may be glued to the phone.
Clement Poisson
crwdns2935283:001/26/10crwdne2935283:0
24 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 13-23, Maness Winter 2010 crwdns2935289:0Cal Poly, Team 13-23, Maness Winter 2010crwdne2935289:0
CPSU-MANESS-W10S13G23
crwdns2935297:096crwdne2935297:0
crwdns2936753:030crwdne2936753:0 37
crwdns2942667:0crwdne2942667:0 6,212
