Palm TX Battery Pack Replacement
  1. Palm TX Battery Pack Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Palm TX Battery Pack Replacement, Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Orient the device so that the display faces forward.
    • Remove the stylus from the right side.
  2. Palm TX Battery Pack Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn over the device so that the back panel faces forward.
    • Use a T5 Torx screwdriver to remove the four 6.35mm corner screws.
  3. Palm TX Battery Pack Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Palm TX Battery Pack Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the device so that the display faces forward.
    • Insert a plastic opening tool with the angled tip pointing downward into the crevice on the left side of the device.
    • Pry along the crevice to loosen the back panel.
    • Repeat this process for the right side.
  4. Palm TX Battery Pack Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Palm TX Battery Pack Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully pry the back panel to open the device.
    • Be careful not to break the wire that connects the battery pack to the motherboard.
    • When reassembling, snap the back panel back into place and then insert the top cover.
  5. Palm TX Battery Pack Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Palm TX Battery Pack Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to peel the battery pack from the back panel.
    • The battery pack is glued to the back panel so removing it may require considerable effort.
  6. Palm TX Battery Pack Replacement, Battery Pack: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Palm TX Battery Pack Replacement, Battery Pack: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a soldering iron to disconnect the battery wires from the motherboard.
    • For soldering instructions, you can view the Soldering Guide.
crwdns2935229:05crwdne2935229:0
Spencer Lewson
crwdns2935283:001/19/11crwdne2935283:0
793 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 1-15, Amido Winter 2011 crwdns2935289:0Cal Poly, Team 1-15, Amido Winter 2011crwdne2935289:0
CPSU-AMIDO-W11S1G15
In step 1 - Also remove the cover hinge by sliding downwards
In step 3 - there are actually 2 crevices on the left side of the device. Use the larger, which originally held the cover hinge (the smaller crevice seems to remove the facia)
Jack - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 57
crwdns2942667:0crwdne2942667:0 7,816
