Palm TX Back Panel Replacement
    1. Palm TX Back Panel Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Palm TX Back Panel Replacement, Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Orient the device so that the display faces forward.
      • Remove the stylus from the right side.
    2. Palm TX Back Panel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn over the device so that the back panel faces forward.
      • Use a T5 Torx screwdriver to remove the four 6.35mm corner screws.
    3. Palm TX Back Panel Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Palm TX Back Panel Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Rotate the device so that the display faces forward.
      • Insert a plastic opening tool with the angled tip pointing downward into the crevice on the left side of the device.
      • Pry along the crevice to loosen the back panel.
      • Repeat this process for the right side.
    4. Palm TX Back Panel Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Palm TX Back Panel Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Carefully pry the back panel to open the device.
      • Be careful not to break the wire that connects the battery pack to the motherboard.
      • When reassembling, snap the back panel back into place and then insert the top cover.
    5. Palm TX Back Panel Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Palm TX Back Panel Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a plastic opening tool to peel the battery pack from the back panel.
      • The battery pack is glued to the back panel so removing it may require considerable effort.
Spencer Lewson
crwdns2935283:001/19/11crwdne2935283:0
793 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 1-15, Amido Winter 2011 crwdns2935289:0Cal Poly, Team 1-15, Amido Winter 2011crwdne2935289:0
CPSU-AMIDO-W11S1G15
crwdns2935297:084crwdne2935297:0
crwdns2936753:07crwdne2936753:0 33
crwdns2936753:030crwdne2936753:0 52
crwdns2942667:0crwdne2942667:0 2,133
