Palm Pre Keypad Control Board Replacement
crwdns2869540:0crwdne2869540:0: 1322
2
15
74
1,322
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:010crwdne2931287:0
crwdns2955970:0crwdne2955970:0: crwdns2937803:0crwdne2937803:0
    1. Palm Pre Keypad Control Board Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Make sure your Palm Pre is turned off before disassembling the phone.
      • Snap off the back panel to reveal the battery.
    2. Palm Pre Keypad Control Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully pull up on the tab to remove the current battery.
    1. Palm Pre Keypad Control Board Replacement, Antenna: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Palm Pre Keypad Control Board Replacement, Antenna: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the T5 Torx Screwdriver to remove the six screws holding the backing frame in place.
    2. Palm Pre Keypad Control Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate the hinge that covers the black and white GPS and DIV antennas. (The hinge will be located in the red box as portrayed in the picture.)
      • Use a spudger to pry open the hinge.
      • Use tweezers to disconnect the antennas from the keypad control board.
    3. Palm Pre Keypad Control Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Palm Pre Keypad Control Board Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a spudger to pry off the (black and yellow) back frame.
      • Disregard the main part of the phone at this point and look only at the inside of the removed back frame. (You will need the main part of the phone for access to the keyboard and motherboard)
    4. Palm Pre Keypad Control Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Find the small circuit board at the top right and desolder the wires that are connected to it.
      • This step is only necessary for antenna removal.
    1. Palm Pre Keypad Control Board Replacement, Keypad Control Board: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two ribbon cable connectors using tweezers.
    2. Palm Pre Keypad Control Board Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Palm Pre Keypad Control Board Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a spudger to remove the keypad control board.
      • There is heavy adhesive connecting this part to the keypad sensors.
noha
crwdns2935283:004/12/12crwdne2935283:0
139 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 7-31, Maness Spring 2012 crwdns2935289:0Cal Poly, Team 7-31, Maness Spring 2012crwdne2935289:0
CPSU-MANESS-S12S7G31
crwdns2935297:096crwdne2935297:0
crwdns2936753:030crwdne2936753:0 74
crwdns2959996:0crwdne2959996:0 1,322
