Push in the button at the bottom of the phone, and lift the back cap off.
Turn phone over on its left side and remove single phillip's head screw using the Phillips #0 screwdriver.
After screw is removed take the plastic opening tool and apply slight pressure to even out bends in the metal
Insert charger to check adjustments to metal outlet
