Palm Centro Speakers Replacement
  1. Palm Centro Speakers Replacement, Disassembling Palm Centro Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Palm Centro Speakers Replacement, Disassembling Palm Centro Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press and slide open the battery cover.
  2. Palm Centro Speakers Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Caution: Turn cell phone off before removing battery!
    • Press battery to the right.
    • Then lift up battery pack to remove.
  3. Palm Centro Speakers Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Phone with battery removed
  4. Palm Centro Speakers Replacement, Back Housing: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the touchpad pen from the top left corner on the back to reveal the last of 6 screws to be removed.
  5. Palm Centro Speakers Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the rubber cap at the top right to reveal the sixth screw.
    • Caution: There is a small Palm sticker under the rubber cap. Tampering with or removing this sticker will void your warranty!
    • Remove the six screws using the T5 Torx screwdriver.
  6. Palm Centro Speakers Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Palm Centro Speakers Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the SIM card so housing can be separated.
  7. Palm Centro Speakers Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Palm Centro Speakers Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic pry tool to separate the bottom of the case to remove the small plastic insert.
  8. Palm Centro Speakers Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Palm Centro Speakers Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the small plastic insert at the bottom of the phone.
  9. Palm Centro Speakers Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Palm Centro Speakers Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Continue with plastic pry tool all the way around the phone to remove the back housing.
  10. Palm Centro Speakers Replacement, Logic Board: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully peel back the tape holding the speaker (left) and keyboard (right) connection tabs in place.
  11. Palm Centro Speakers Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the plastic prying tool, lift the tabs and carefully pull the contact connections out on both sides.
    • Be very careful, these electronics are delicate!
  12. Palm Centro Speakers Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the logic board from the case by lifting and pulling out the bottom.
  13. Palm Centro Speakers Replacement, Speakers: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Palm Centro Speakers Replacement, Speakers: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Palm Centro Speakers Replacement, Speakers: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry the four plastic latches free that connect the antenna to the logic board.
    • Excessive force may damage your logic board!
    • Remove the antenna from the logic board.
  14. Palm Centro Speakers Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The internal speaker is attached to the antenna. To remove it, pry the speaker from the antenna using the tip of your screwdriver.
    • The speaker should be placed back into its spot in the correct position. Take notice of the gold connectors
Kevin
crwdns2935283:004/12/10crwdne2935283:0
31 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 15-49, Garner Spring 2010 crwdns2935289:0Cal Poly, Team 15-49, Garner Spring 2010crwdne2935289:0
CPSU-GARNER-S10S15G49
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 1,505
