This guide show you how to remove and replace the Palm Centro's speakers
Press and slide open the battery cover.
Press battery to the right.
Then lift up battery pack to remove.
Remove the touchpad pen from the top left corner on the back to reveal the last of 6 screws to be removed.
Lift the rubber cap at the top right to reveal the sixth screw.
Remove the six screws using the T5 Torx screwdriver.
Remove the SIM card so housing can be separated.
Use a plastic pry tool to separate the bottom of the case to remove the small plastic insert.
Remove the small plastic insert at the bottom of the phone.
Continue with plastic pry tool all the way around the phone to remove the back housing.
Carefully peel back the tape holding the speaker (left) and keyboard (right) connection tabs in place.
Using the plastic prying tool, lift the tabs and carefully pull the contact connections out on both sides.
Separate the logic board from the case by lifting and pulling out the bottom.
Pry the four plastic latches free that connect the antenna to the logic board.
Remove the antenna from the logic board.
The internal speaker is attached to the antenna. To remove it, pry the speaker from the antenna using the tip of your screwdriver.
