Pacific Image Electronics CS3600 Motor Replacement
  1. Pacific Image Electronics CS3600 Motor Replacement, Motor: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pacific Image Electronics CS3600 Motor Replacement, Motor: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To start, open the device by removing the 5, 5mm x 9mm screws, with a Phillips J1 screwdriver.
  2. Pacific Image Electronics CS3600 Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Next, remove the 5 9mm x 5mm screws from the circled spots with a Phillips J1 screwdriver.
  3. Pacific Image Electronics CS3600 Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the screws are removed, carefully lift the motor casing out of the device.
    • The plastic piece circled acts as a clamp, lift the casing up and towards you to detach the casing.
  4. Pacific Image Electronics CS3600 Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pacific Image Electronics CS3600 Motor Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now, with the motor casing in hand, remove the two 9mm x 5mm screw and washer at the top of the motor casing using a J1 screwdriver.
    • Gently pull the motor away from the casing to expose the wires.
  5. Pacific Image Electronics CS3600 Motor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully desolder the wires from their contact point on the circuit board.
    • You have now successfully removed the motor!
Alessia Carlton
crwdns2935283:003/21/17crwdne2935283:0
201 crwdns2915208:0crwdne2915208:0
Texas Tech, Team S46-G2, Bennett Spring 2017 crwdns2935289:0Texas Tech, Team S46-G2, Bennett Spring 2017crwdne2935289:0
TTU-BENNETT-S17S46G2
crwdns2942667:0crwdne2942667:0 350
