The only tool required for lens removal is a JIS (J0) screwdriver bit. Replacing the lens will enable you to continue scanning images onto a computer.
            Use the J0 screwdriver to remove the 5 following screws that are 9 mm x 7 mm.
            Using light force open the device by pulling at the seam.
            Use the J0 screwdriver to remove the screws that are 7 mm x 6 mm.
            Once the screws are removed and casing removed the lens is revealed.
            Simply remove the lens and replace accordingly!
