Before beginning, please know that you will be completely taking apart the device in order to get to the button from the inside.
            Begin opening the device by unscrewing the 5 following 9mm x 7mm screws with a J1 screwdriver.
            Once the screws have been removed, with light force open the scanner by pulling it apart at the seam.
            With a JIS J0 screwdriver remove the 1 screw that is 7mm x 6mm.
            Lift and move the plate with the connected wires out of the way.
            Remove the spring and replace it with a new one.
