PSP E1000 / E1004
not read UMD games and you haven't indication for insertion games. The problem probably is in UMD switch.
You can see the video:
crwdns2936621:0crwdne2936621:0
If you haven't indication for inserted disk the problem probably is in UMD switch.
Unhook the door metal plate and disassemble UMD door.
With a screwdriver I short the UMD switch to test the laser.
I must disconnect 7x cables and unscrew a screw.
Now I disconnect the battery connector and here is the mainboard.
I used soldering station to remove the old one and put the new one (UMD switch).
crwdns2935229:05crwdne2935229:0
crwdns2917034:0crwdne2917034:0
Step 2 - picture number 3 is wrong, I broke off a little part of my PSP E1004. The left arrow points up but you have to pull it down, while trying to pry gently to the right. I learned the hard way after I managed to take it off.
