How to fix your pspe with not working screen (black screen backlight not working)
This is the front and back of the PSP E1000
Remove all four screws on the back using the same bit as before.
Then remove the two top screws.
Insert wisdom here.Gently unclip the display ribbon cable and remove it Then set the display to the side Untape the front panel ribbon cable, unclip it, then remove it.
Remove the ribbon cable and power cable Gently lift the button assembly and charge port The shoulder button is taped down so slide a spudger under the button and gently peel it off
Unclip and remove the two marked ribbon cables Remove the marked screw and lift the analog stick out Lift the button pad carefully and peel off the shoulder button When reassembling install the joystick before the buttons.
Unclip both ribbon cables and remove them Remove the marked screw on the mainboard Lift the bottom of the mainboard up and slide it out For reinstallation make sure that the power switch cover is installed before it is screwed in. It has to be unscrewed to do the installation
Congratulations you have disassembled your PSP E1000. Have fun with the reassembly!
disassemble the console, take a multimeter and measure whether the fuse conducts current, if not, remove the fuse with scissors from a 3D printer or pliers and connect the 2 elements together
