PSP 300x Trigger Buttons Replacement
    1. PSP 300x Trigger Buttons Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PSP 300x Trigger Buttons Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PSP 300x Trigger Buttons Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Place the PSP face down and locate the battery cover on the left side of the device.
      • Lift and remove the battery cover to reveal the battery.
      • Remove the battery.
    1. PSP 300x Trigger Buttons Replacement, Front Casing: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Peel back the warranty sticker that is behind the battery with a spudger or your fingernail.
    2. PSP 300x Trigger Buttons Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PSP 300x Trigger Buttons Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unscrew all four screws from the back of the PSP with the Phillips #00 Screwdriver.
      • Two are located behind the battery's warranty sticker.
      • Two are located on the right side of the PSP.
    3. PSP 300x Trigger Buttons Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Next, unscrew the two screws located at the top of the PSP.
    4. PSP 300x Trigger Buttons Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Then, remove the single screw from the bottom edge of the PSP (which is positioned next to the barcode).
    5. PSP 300x Trigger Buttons Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PSP 300x Trigger Buttons Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Slide the spudger in between the outer casing of the PSP, beginning at the "R" shoulder button, and gently pry off the casing.
      • Remove the front casing completely.
    1. PSP 300x Trigger Buttons Replacement, LCD Screen: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PSP 300x Trigger Buttons Replacement, LCD Screen: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Push the homebar to the right to release the tab located on the right side of the LCD screen.
      • DO NOT completely remove the homebar, as it is still connected by ribbon cables.
    2. PSP 300x Trigger Buttons Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PSP 300x Trigger Buttons Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PSP 300x Trigger Buttons Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Slowly lift the LCD screen off the PSP starting at the top edge corner.
      • Again, the LCD screen is attached by ribbon cables, so do not remove it completely.
      • Orientation of PSP is flipped in photo.
    3. PSP 300x Trigger Buttons Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PSP 300x Trigger Buttons Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip the small brown locks on the four ribbon cable connectors up using a spudger or fingernail.
      • Pull all four ribbon cables out.
      • Now remove the LCD screen and homebar from the PSP.
    4. PSP 300x Trigger Buttons Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the metal tab that lies above the LCD screen.
      • Upon reassembly, make note that the stamped lettering faces down, and the large tab fits just above the motherboard to the right hand side of the left trigger.
    1. PSP 300x Trigger Buttons Replacement, Trigger Buttons: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the screw securing 'L' trigger to the PSP.
    2. PSP 300x Trigger Buttons Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the white plastic piece that holds the 'L' trigger in place.
    3. PSP 300x Trigger Buttons Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 'L' trigger from the PSP.
    4. PSP 300x Trigger Buttons Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the screw securing the 'R' trigger.
    5. PSP 300x Trigger Buttons Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the white plastic piece that holds the 'R' trigger in place.
    6. PSP 300x Trigger Buttons Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 'R' trigger from the PSP.
crwdns2935229:011crwdne2935229:0
cmcevill
crwdns2935283:011/05/09crwdne2935283:0
541 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 19-2, Maness Fall 2009 crwdns2935289:0Cal Poly, Team 19-2, Maness Fall 2009crwdne2935289:0
CPSU-MANESS-F09S19G2
crwdns2936753:07crwdne2936753:0 64
crwdns2936753:030crwdne2936753:0 261
crwdns2942667:0crwdne2942667:0 24,754
