PSP 2000 Front Casing Replacement
crwdns2869540:0crwdne2869540:0: 3.4万
15
96
413
33,757
crwdns2955950:0crwdne2955950:0: 3
crwdns2960002:01crwdne2960002:0, crwdns2960008:02crwdne2960008:0
crwdns2959984:0crwdne2959984:0: 18
crwdns2959974:018crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 18
crwdns2959982:018crwdne2959982:0
crwdns2955944:0crwdne2955944:0: 5 - 10 crwdns2931279:0crwdne2931279:0
crwdns2955970:0crwdne2955970:0: crwdns2937799:0crwdne2937799:0
Paint job scratched? Going custom? Change out your faceplate assembly!
    1. PSP 2000 Front Casing Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PSP 2000 Front Casing Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PSP 2000 Front Casing Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Place PSP face down, so that the UMD Drive is facing upwards.
      • Locate the battery door and open.
      • Remove the battery from inside.
    1. PSP 2000 Front Casing Replacement, Front Casing: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • This step requires the removal of the warranty sticker. Removing the sticker will void the warranty. According to the FTC removing this will not void your warranty.
      • Locate the sticker in the battery compartment labeled: "En: Warranty Void if Seal Damaged."
      • Remove the sticker using the PSP Opening Tools.
      • Under the sticker is a 5mm Phillips screw needed in the next step.
    2. PSP 2000 Front Casing Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PSP 2000 Front Casing Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove four 5 mm Phillips from the case.
      • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
    3. PSP 2000 Front Casing Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PSP 2000 Front Casing Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the following screws from around the bezel:
      • Two 4 mm Phillips
      • One 5 mm Phillips
      • The two shorter 4 mm screws are on the top of the PSP; the longer 5 mm screw is on the bottom.
    4. PSP 2000 Front Casing Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PSP 2000 Front Casing Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Gently pry the front bezel away from the casing using a PSP opening tool.
      • Start on the right hand side of the PSP bezel, and carefully work the tool around the side.
      • If you want to clean the control buttons or D-pad, you can easily pop them out once the faceplate is off and wipe them clean.
crwdns2935229:018crwdne2935229:0
pepe32290
crwdns2935283:010/19/09crwdne2935283:0
1,799 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 6-3, Maness Fall 2009 crwdns2935289:0Cal Poly, Team 6-3, Maness Fall 2009crwdne2935289:0
CPSU-MANESS-F09S6G3
crwdns2935297:0108crwdne2935297:0
Does the front casing also have the plastic glass screen on it as well? Or is that separate?
Arthur - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
sorry this is a decade too late HA. i just did a swap for the plastic screen cover and yes, for anyone in the future, the plastic cover is on the front shell piece, you will need some tweezers or something narrow to get the plastic screen popped off, dont crack the front shell, the bottom gets fragile so just be slow and methodical. but its an easy swap, maybe 15 minutes. good time to clear out the lint around the joystick as well.
Scott Munier - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 15
crwdns2936753:07crwdne2936753:0 96
crwdns2936753:030crwdne2936753:0 413
crwdns2959996:0crwdne2959996:0 33,757
