crwdns2862627:0crwdne2862627:0
crwdns2862628:0crwdne2862628:0
crwdns2862591:0crwdne2862591:0
crwdns2862592:0crwdne2862592:0
crwdns2959928:0crwdne2959928:0 ↓Cracked/broken LCD? No problem! Replace it with ease.
Sony PSP 2000 LCD$59.99
Sony PSP 2000 Home Bar$7.99
Place PSP face down, so that the UMD Drive is facing upwards.
Locate the battery door and open.
Remove the battery from inside.
Locate the sticker in the battery compartment labeled: "En: Warranty Void if Seal Damaged."
Remove the sticker using the PSP Opening Tools.
Remove four 5 mm Phillips from the case.
Remove the following screws from around the bezel:
Two 4 mm Phillips
One 5 mm Phillips
Gently pry the front bezel away from the casing using a PSP opening tool.
Start on the right hand side of the PSP bezel, and carefully work the tool around the side.
Remove the home bar by gently prying on the left and right sides of it with the opening tools. Lift the bar out of the device.
With the home bar out of the way, gently pry up the display using the opening tools.
Lift the black tabs of the ribbon cable connectors using a opening tool. Pull the ribbons out towards the bottom of the PSP to disconnect.
Gently lift out the display.
crwdns2935229:068crwdne2935229:0
That does’t seem that hard. Is this tutorial working with the PSP2004?
Jack Galinski - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Yes it is, just did it :)
Billy - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Thanks for the great tut just fixed a trash find psp with a cracked lcd.
myhero667 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Parfait tutoriel pour remplacer mon écran de PSP 2004. Un grand merci
Ramius59 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I was wondering why after replacing the screen that the new one only shows a blank black screen. The backlight turns on and it plays the boot up sequence and you can play around on the Home Screen, but you just cant see what you’re doing on the screen. Everything seems connected right. Any suggestions??
Dylan Thomas - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
