PS4 Dualshock 4 trigger reassembly
  1. PS4 Dualshock 4 trigger reassembly, Preparing the triggers: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PS4 Dualshock 4 trigger reassembly, Preparing the triggers: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove these two triggers and springs from the backplate.
    • Find which trigger goes on which side and put the springs in the trigger part facing towards the inside of the controller.
  2. PS4 Dualshock 4 trigger reassembly, Attaching the triggers.: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PS4 Dualshock 4 trigger reassembly, Attaching the triggers.: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On these two clips...
    • Push down the trigger until it clicks on both sides.
    • Make sure that the one spring part is inside the rail (marked cyan) and the other outside the whole assembly (green).
  3. PS4 Dualshock 4 trigger reassembly, Connecting the light bar: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Connect the light bar cable using your fingers. Make sure it is fully pushed down and that is plugged in the right way.
  4. PS4 Dualshock 4 trigger reassembly, Closing the cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PS4 Dualshock 4 trigger reassembly, Closing the cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • close the cover starting from the side of the triggers. Don't worry if it's a bit hard to do so, but be careful so you don't break the plastic between the trigger and the bumper.
    • Push down until it clicks everywhere.
    • Finally, screw in these four screws using a PH0 screwdriver.
crwdns2935229:025crwdne2935229:0
Devnol
crwdns2935283:012/01/18crwdne2935283:0
2.894 crwdns2915208:0crwdne2915208:0
Thank you so much! I had a ps4 controller that had a broken r2 button and i had gotten a replacement (which is now having battery issues) Today I took the old controller apart… the spring had come out of the rail. That was it!
Dee - crwdns2934203:0crwdne2934203:0
This guide is wrong. The top part spring should be inside the trigger, if you look at the other trigger it’s not exposed.
https://pureplaystation.com/wp-content/u...
Angus Yung - crwdns2934203:0crwdne2934203:0
Thanks for pointing it out. I do not have this controller anymore as it was from a repair job so unfortunately, I cannot correct it. If you or someone else happens to have one and is able to take high-quality pictures I’d be more than grateful to accept your correction.
Devnol -
crwdns2936751:024crwdne2936751:0 14
crwdns2936753:07crwdne2936753:0 96
crwdns2936753:030crwdne2936753:0 497
crwdns2942667:0crwdne2942667:0 49,318
