PS3 Dual Shock 3 Controler Charging Port Replacement
  1. PS3 Dual Shock 3 Controler Charging Port Replacement, Opening the Controller: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 5 screws on the back of the controller.
    • The back housing of the controller can now be removed.
  2. PS3 Dual Shock 3 Controler Charging Port Replacement, Removing the Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove battery by unlatching the battery cables from battery connector clip.
  3. PS3 Dual Shock 3 Controler Charging Port Replacement, Freeing the Motherboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws holding the motherboard to the front controller housing.
    • Next, remove the motherboard assembly from the controller housing. This is done by pressing in the clips on each side of the handle.
    • Freeing the motherboard from the housing will provide better access to the charging port.
  4. PS3 Dual Shock 3 Controler Charging Port Replacement, Preparing the Soldering Station: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Prepare your station for the de-soldering of the charging port.
  5. PS3 Dual Shock 3 Controler Charging Port Replacement, Desoldering: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PS3 Dual Shock 3 Controler Charging Port Replacement, Desoldering: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PS3 Dual Shock 3 Controler Charging Port Replacement, Desoldering: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Desoldering Pump
    $3.99
    • To remove the defective charging port, you will need to de-solder the 9 pins holding the port to the motherboard.
    • First, used the desoldering pump to remove the solder from all 9 pins.
    • Then, use the desoldering wick to remove any excess solder left on the motherboard.
  6. PS3 Dual Shock 3 Controler Charging Port Replacement, Securing New Charging Port: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After the charging port is removed, place the new charging port into position.
    • Hold the new port in place by using a clip to keep it from moving.
  7. PS3 Dual Shock 3 Controler Charging Port Replacement, Soldering The New Port: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PS3 Dual Shock 3 Controler Charging Port Replacement, Soldering The New Port: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Tin the soldering iron before soldering the connections. This is done by applying a small amount of solder to the tip of the hot iron.
    • Solder the 9 pin connections that connect the charging port to the motherboard.
To reassemble your device, follow instructions 1-3 in reverse order.
crwdns2935229:017crwdne2935229:0
Attak
crwdns2935283:012/04/17crwdne2935283:0
658 crwdns2915208:0crwdne2915208:0
crwdns2947412:05crwdne2947412:0
Shall DualShock3 require other than GND and VBUS for charging only
and does DS3 follow the standards of USB-miniB (eg: Data wires flipping).
Sony does have some fame to sacrifice standards over extra capability delivery.
JanLS - crwdns2934203:0crwdne2934203:0
Would you guys happen to know, if my labeling is correct? I’m going to upgrade to USB-C.
https://imgur.com/a/RL68Yw5
Howling Beats - crwdns2934203:0crwdne2934203:0
Thank you it's really useful, tips,
Alan - crwdns2934203:0crwdne2934203:0
Thanks for this. But now there are four different USB charging ports, how to tell which one of them is suitable? kasynparts eg
kasynlife - crwdns2934203:0crwdne2934203:0
please attak if you still using this platfrom i really need you to help me with a ps3 controller pins
Deyaa Alshapshiri - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 13
crwdns2936753:07crwdne2936753:0 72
crwdns2936753:030crwdne2936753:0 347
crwdns2942667:0crwdne2942667:0 23,209
