Unscrew the circled screws in a star pattern using a Philips bit.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to disconnect the fan. Make sure to pull up on the connector and not the wires or the base as both risk damaging the device.
To reassemble your device, follow these instructions in reverse order and make sure to use the cross pattern when reserving the back screws holding the fan in place.
