Replacing the joystick covers will enhance productivity and result in more accurate outputs. In the steps provided below, we have shown you how to efficiently remove and replace the joystick covers.
Insert an opening tool in the gap between the rear and front case.
Pry around the perimeter until the front case releases.
Remove the front case.
Firmly grasp the joystick cover and pull it straight up and off of the controller.
Align the new joystick with the controller's socket; press down until it clicks into place.
Helpful and clear instructions given by the Author. Although an opening tool is definitely overkill for removing the faceplate as it's held on by a few magnets and requires little effort. If the faceplate doesn't come off easily it's probably because you need to remove the circular D-Pad (which the Author mentions in Step 1 - "i")
