The face buttons should be replaced on your PDP Rematch Advanced controller if they take more effort to press down. If you need to replace any of the face buttons, separate the front housing shell from the motherboard with this guide.
Orient the controller so the back side is facing you.
Use a Phillips #000 screwdriver to remove the seven 9 mm screws that secure the back shell.
Pull apart the controller's front and back shells with moderate force.
Peel the rubber piece off the back of the face buttons.
Push all the face buttons out from the front of the shell.
