crwdns2959928:0crwdne2959928:0 ↓The back shell of your PDP Rematch Advanced should be replaced if it's damaged or if you want to swap it out for a different color shell. If you need to replace the back shell, take out the motherboard with this guide.
Orient the controller so the back side is facing you.
Use a Phillips #000 screwdriver to remove the seven 9 mm screws that secure the back shell.
Pull apart the controller's front and back shells with moderate force.
Twist the thumbstick to remove it from the motherboard. Repeat this step if both thumbsticks need to be replaced.
Grab the motor and pull away from the back shell. Repeat for both motors.
Use a Phillips #00 Screwdriver to remove the two 5mm screws from the motherboard.
Remove the motherboard from the back shell using moderate force.
