crwdns2959928:0crwdne2959928:0 ↓The action buttons should be replaced on your PDP Rematch Advanced controller if they take more effort to press down. If you need to replace any of the action buttons, separate the front housing shell from the motherboard with this guide.
Orient the controller so the back side is facing you.
Use a Phillips #000 screwdriver to remove the seven 9 mm screws that secure the back shell.
Pull apart the controller's front and back shells with moderate force.
Peel the rubber gasket off the back of the action buttons.
Push all the action buttons out from the front of the shell.
