PDP Afterglow Wired Xbox 360 Controller LEDs Replacement
  1. PDP Afterglow Wired Xbox 360 Controller LEDs Replacement, Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PDP Afterglow Wired Xbox 360 Controller LEDs Replacement, Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Loosen the seven 11 mm Phillips #0 screws located on the back of the controller.
  2. PDP Afterglow Wired Xbox 360 Controller LEDs Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a plastic opening tool, pry the back cover from the front.
    • The covers should separate without needing a plastic opening tool, but in some cases you may need to use it.
  3. PDP Afterglow Wired Xbox 360 Controller LEDs Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the top cover from the bottom and place next to each other.
  4. PDP Afterglow Wired Xbox 360 Controller LEDs Replacement, LEDs: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PDP Afterglow Wired Xbox 360 Controller LEDs Replacement, LEDs: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the logic board from the controller casing by lifting up and pulling out.
  5. PDP Afterglow Wired Xbox 360 Controller LEDs Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the LED (s) that needs to be replaced.
    • Once the LED has been located, flip the logic board to the other side and locate the pins associated with the LED that needs to be replaced.
  6. PDP Afterglow Wired Xbox 360 Controller LEDs Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Desolder the LED from the logic board.
    • The soldering iron is very hot and can harm you or the device if used improperly.
Joi Officer
crwdns2935283:009/17/15crwdne2935283:0
298 crwdns2915208:0crwdne2915208:0
IUPUI, Team 3-1, Harley Fall 2015 crwdns2935289:0IUPUI, Team 3-1, Harley Fall 2015crwdne2935289:0
IUPUI-HARLEY-F15S3G1
crwdns2942667:0crwdne2942667:0 2,263
