Unlock the lock circled in red.
Lift the battery while unlocking the lock circled in red.
Unscrew the five screws circled in red.
Slide the plate in the direction of the red arrow.
Unscrew the two screws circled in red
Press a paper clip in the three places marked in red
Lift the keyboard and feel free to put some strength
Disconnect the three framed connectors in red
Pull the white drawer in the direction of the arrow to unlock the connector
Disconnect the red circled connector
Pull the black drawer in the direction of the arrow to unlock the connector
Lift the flap that holds the connector circled in red
Remove the keyboard
To reassemble your device, follow the instructions in reverse order.
crwdns2934873:0crwdne2934873:0
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
I wish to know whether it’s possible to pry off the key to clean off the contacts. (I spilled coffee on the keyboard).
Fortunately for me, the key was on the edge of the board (the down arrow key). It was stuck on.
I lifted the key up as much as I could and I cleaned it with Deoxit. That did the trick. My keyboard is now working.
Thanks for the steps!
Oops. Spoke too soon. There’s something wrong with the keyboard: the INSERT key (ESC -[2~ ) is stuck. Also, there’s a red light under the keyboard. I’m not sure what that all means…
Great instructions, but for my laptop, step 7 only indicated three of seven places (the other four are the top centre of the keyboard, and the three points symmetrical to the 3 you’ve indacted, on the right hand side of the keyboard).
