Ozeri Pronto ZK14-S Wire Replacement
  1. Ozeri Pronto ZK14-S Wire Replacement, Panel Removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ozeri Pronto ZK14-S Wire Replacement, Panel Removal: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Twist the plastic plate slowly to the left to pull it away.
  2. Ozeri Pronto ZK14-S Wire Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up the sticker at the bottom where the “Ozeri” logo is to reveal a screw.
    • The sticker does not need to be completely removed.
  3. Ozeri Pronto ZK14-S Wire Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a 2.0 Flathead screwdriver, remove the 9.50 mm Phillips head screw under the sticker.
  4. Ozeri Pronto ZK14-S Wire Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ozeri Pronto ZK14-S Wire Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a 2.0 Flathead screwdriver, remove the two 18.76 mm Phillips head screws in the plate stand.
  5. Ozeri Pronto ZK14-S Wire Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ozeri Pronto ZK14-S Wire Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a 2.0 Flathead screwdriver, remove the 9.44 mm Phillips head screw on the edge opposite to the LCD screen.
  6. Ozeri Pronto ZK14-S Wire Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the device over so the back panel is facing up.
  7. Ozeri Pronto ZK14-S Wire Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the iFixit opening tool, pry off the two rubber stubs on the right side and the two rubber stubs on the left side of the bottom of the device.
  8. Ozeri Pronto ZK14-S Wire Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a 2.0 Flathead screwdriver, remove the four 9.46 mm Phillips head screws that were under the rubber stubs.
  9. Ozeri Pronto ZK14-S Wire Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ozeri Pronto ZK14-S Wire Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry apart the two panels to separate them from each other.
    • Flip the device over so the LCD is facing up. Flip the front panel over on its side.
    • Be careful when separating the panels to avoid damaging the wires they are connected by.
  10. Ozeri Pronto ZK14-S Wire Replacement, Wire: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ozeri Pronto ZK14-S Wire Replacement, Wire: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    • Using the 2.0 Flathead screwdriver, remove the three 7.20 mm screws on the back of the center LCD motherboard.
  11. Ozeri Pronto ZK14-S Wire Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Stand the center motherboard up.
    • Be careful when standing up the LCD motherboard to avoid damaging the wires it is connected to.
  12. Ozeri Pronto ZK14-S Wire Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Desolder the post the damaged wire is attached to on the motherboard.
    • Use caution when handling the soldering iron since it can get very hot.
  13. Ozeri Pronto ZK14-S Wire Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the iOpener, warm the glue on the weight sensor the other end of the damaged wire is attached to.
    • Use caution when handling the iOpener since it can get very hot.
    • Refer to the following guide for detailed instructions on how to use the iOpener: iOpener (Legacy) Instructions
  14. Ozeri Pronto ZK14-S Wire Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the nylon or metal spudger, detach the end of the damaged wire from the weight sensor.
    • Repeat steps 13 and 14 to remove the end of a damaged wire from the other two motherboards.
Oneika White
crwdns2935283:010/01/15crwdne2935283:0
712 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-4, Leahy Fall 2015 crwdns2935289:0USF Tampa, Team 1-4, Leahy Fall 2015crwdne2935289:0
USFT-LEAHY-F15S1G4
crwdns2942667:0crwdne2942667:0 4,775
