If your volume, power, or slide buttons are not working, use this guide to help fix or replace them.
            Use a Metal Spudger to remove the ear muffs from the headset.
            Using a Phillips #000 screwdriver, remove the 1st 9mm screw that secures the left head piece.
            Using a Phillips #000 screwdriver, remove the 2nd 9mm screw that secures the left head piece.
            Using a Phillips #000 screwdriver, remove the 3rd 9mm screw that secures the left head piece.
            Using a Phillips #000 screwdriver, remove the 4th 9mm screw that secures the left head piece.
            Using a Phillips #000 screwdriver, remove the 5th 9mm screw that secures the left head piece.
            Using a Phillips #000 screwdriver, remove the last 9mm screw that secures the left head piece.
            Use your hands or the metal spudger to pry open the earpiece to find the green panel.
            After opening the ear piece find the green panel and look for the 1st 7mm screw. Use the Phillips #000 screwdriver to remove the screw that is holding the green panel in place.
            Use the Phillips #000 screwdriver to remove the 2nd 7mm screw that is holding the green panel in place.
            Using either your hand or the tweezers carefully remove the green panel from inside the headset.
            After removing the panel, use either your hands or tweezers to carefully remove and replace the volume and power buttons.
            Lastly, remove the slide button from the headset using a pair of tweezers.
