Ozeino OW810 Headband Cushion Replacement
  1. Ozeino OW810 Headband Cushion Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert a nylon spudger in the seam between the right ear pad and the driver housing.
    • Pry the right ear pad off.
  2. Ozeino OW810 Headband Cushion Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #000 screwdriver to remove the six 3.2 mm screws securing the right driver housing.
  3. Ozeino OW810 Headband Cushion Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the driver housing off, with care not to strain the connected cables.
  4. Ozeino OW810 Headband Cushion Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a nylon spudger to gently pry out the battery.
    • Do not use a metal spudger to pry out the battery. Metal spudgers can easily puncture the battery.
  5. Ozeino OW810 Headband Cushion Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove tape from the battery.
    • Pull the circuit board up along with the wiring from either side.
    • Replace battery.
  6. Ozeino OW810 Headband Cushion Replacement, Volume Buttons: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Metal Spudger to remove the ear muffs from the headset.
  7. Ozeino OW810 Headband Cushion Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #000 screwdriver, remove the 1st 9mm screw that secures the left head piece.
  8. Ozeino OW810 Headband Cushion Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #000 screwdriver, remove the 2nd 9mm screw that secures the left head piece.
  9. Ozeino OW810 Headband Cushion Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #000 screwdriver, remove the 3rd 9mm screw that secures the left head piece.
  10. Ozeino OW810 Headband Cushion Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #000 screwdriver, remove the 4th 9mm screw that secures the left head piece.
  11. Ozeino OW810 Headband Cushion Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #000 screwdriver, remove the 5th 9mm screw that secures the left head piece.
  12. Ozeino OW810 Headband Cushion Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #000 screwdriver, remove the last 9mm screw that secures the left head piece.
  13. Ozeino OW810 Headband Cushion Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your hands or the metal spudger to pry open the earpiece to find the green panel.
  14. Ozeino OW810 Headband Cushion Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After opening the ear piece find the green panel and look for the 1st 7mm screw. Use the Phillips #000 screwdriver to remove the screw that is holding the green panel in place.
  15. Ozeino OW810 Headband Cushion Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Phillips #000 screwdriver to remove the 2nd 7mm screw that is holding the green panel in place.
  16. Ozeino OW810 Headband Cushion Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using either your hand or the tweezers carefully remove the green panel from inside the headset.
  17. Ozeino OW810 Headband Cushion Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing the panel, use either your hands or tweezers to carefully remove and replace the volume and power buttons.
  18. Ozeino OW810 Headband Cushion Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lastly, remove the slide button from the headset using a pair of tweezers.
  19. Ozeino OW810 Headband Cushion Replacement, Motherboard: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before beginning this guide make sure you have gathered your tools.
    • You will need The Marlin Screw Driver Set
    • It will take approximately 3 min to get assembled
    • Once your tools are gathered you may begin the guide
  20. Ozeino OW810 Headband Cushion Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before beginning detach the ear muff
    • Use the Metal Spudger to help detach
    • Highlighted in the red circle is what needs to be detached in order to start the guide
    • Everything will be located on the left side of The Ozeino OW810
  21. Ozeino OW810 Headband Cushion Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After detaching the ear muff gather your tools
    • You will need The Marlin Screw Driver set
    • Take The Phillips #0 screwdriver to begin
  22. Ozeino OW810 Headband Cushion Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Highlighted in red is the first screw needed to remove
    • Use Phillips #0 to unscrew
  23. Ozeino OW810 Headband Cushion Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Highlighted is the second screw needed to be removed
    • Use Phillips #0 screwdriver
  24. Ozeino OW810 Headband Cushion Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Highlighted is the third screw needed to be removed
    • Use Phillips #0
  25. Ozeino OW810 Headband Cushion Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Highlighted is the fourth screw needed to be removed
  26. Ozeino OW810 Headband Cushion Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Highlighted is the fifth screw needed to be removed
  27. Ozeino OW810 Headband Cushion Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Highlighted is the last screw needed to be removed
    • You should have unscrewed 6 screws from the ear muff
  28. Ozeino OW810 Headband Cushion Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After unscrewing the screws from the ear muff remove the piece
    • Locate circuit board highlighted
  29. Ozeino OW810 Headband Cushion Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Highlighted is the screw needed to be removed from the circuit board
  30. Ozeino OW810 Headband Cushion Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After following the guide and detaching the ear muffs begging locating the plug jack and begin replacement.
    • The replacement should take approximately 10 minutes
    • To reassemble your device, follow these instructions in reverse order.
  31. Ozeino OW810 Headband Cushion Replacement, Headband Cushion: crwdns2935265:032crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ozeino OW810 Headband Cushion Replacement, Headband Cushion: crwdns2935265:032crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove both earmuff pieces
  32. Ozeino OW810 Headband Cushion Replacement: crwdns2935265:033crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ozeino OW810 Headband Cushion Replacement: crwdns2935265:033crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ozeino OW810 Headband Cushion Replacement: crwdns2935265:033crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew all 5 3.175mm screws from each side of the ear pieces
  33. Ozeino OW810 Headband Cushion Replacement: crwdns2935265:034crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull sound pieces (that go towards the ear) off both sides of the headset
  34. Ozeino OW810 Headband Cushion Replacement: crwdns2935265:035crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry the silver battery off of the frame
  35. Ozeino OW810 Headband Cushion Replacement: crwdns2935265:036crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully unscrew the 2mm screw on the green circuit board
    • Pull circuit board out carefully
  36. Ozeino OW810 Headband Cushion Replacement: crwdns2935265:037crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ozeino OW810 Headband Cushion Replacement: crwdns2935265:037crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ozeino OW810 Headband Cushion Replacement: crwdns2935265:037crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once circuit board is removed, unscrew the four screws on the frame beneath it
    • Repeat on other side
  37. Ozeino OW810 Headband Cushion Replacement: crwdns2935265:038crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the light board portion from the back of the earpiece
  38. Ozeino OW810 Headband Cushion Replacement: crwdns2935265:039crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ozeino OW810 Headband Cushion Replacement: crwdns2935265:039crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ozeino OW810 Headband Cushion Replacement: crwdns2935265:039crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove 3.174mm screws from the white framing
  39. Ozeino OW810 Headband Cushion Replacement: crwdns2935265:040crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ozeino OW810 Headband Cushion Replacement: crwdns2935265:040crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 2 4mm screws in the black piece of the headband
  40. Ozeino OW810 Headband Cushion Replacement: crwdns2935265:041crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull on the earpiece framing to remove it from the headband
  41. Ozeino OW810 Headband Cushion Replacement: crwdns2935265:042crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove and replace the cushioning
Rylee
crwdns2935283:002/19/25crwdne2935283:0
571 crwdns2915208:0crwdne2915208:0
Sam Houston State, Team 17-6, Thornton Spring 2025 crwdns2935289:0Sam Houston State, Team 17-6, Thornton Spring 2025crwdne2935289:0
SHSU-THORNTON-S25S17G6
crwdns2942667:0crwdne2942667:0 56
