If you are experiencing issues with your Ozeino OW810 headband cushion or just find yourself wanting to replace it, use this guide to help.
The headband cushion helps protect the top of the head from the harshness of the plastic head piece. This guide gives you step by step directions on how to take the headset apart and remove the cushion.
Before following this guide review the prerequisite guides, they go into more detail about the initial taking apart sequence.
Insert a nylon spudger in the seam between the right ear pad and the driver housing.
Pry the right ear pad off.
Use a Phillips #000 screwdriver to remove the six 3.2 mm screws securing the right driver housing.
Lift the driver housing off, with care not to strain the connected cables.
Use a nylon spudger to gently pry out the battery.
Remove tape from the battery.
Pull the circuit board up along with the wiring from either side.
Replace battery.
Use a Metal Spudger to remove the ear muffs from the headset.
Using a Phillips #000 screwdriver, remove the 1st 9mm screw that secures the left head piece.
Using a Phillips #000 screwdriver, remove the 2nd 9mm screw that secures the left head piece.
Using a Phillips #000 screwdriver, remove the 3rd 9mm screw that secures the left head piece.
Using a Phillips #000 screwdriver, remove the 4th 9mm screw that secures the left head piece.
Using a Phillips #000 screwdriver, remove the 5th 9mm screw that secures the left head piece.
Using a Phillips #000 screwdriver, remove the last 9mm screw that secures the left head piece.
Use your hands or the metal spudger to pry open the earpiece to find the green panel.
After opening the ear piece find the green panel and look for the 1st 7mm screw. Use the Phillips #000 screwdriver to remove the screw that is holding the green panel in place.
Use the Phillips #000 screwdriver to remove the 2nd 7mm screw that is holding the green panel in place.
Using either your hand or the tweezers carefully remove the green panel from inside the headset.
After removing the panel, use either your hands or tweezers to carefully remove and replace the volume and power buttons.
Lastly, remove the slide button from the headset using a pair of tweezers.
Before beginning this guide make sure you have gathered your tools.
You will need The Marlin Screw Driver Set
It will take approximately 3 min to get assembled
Once your tools are gathered you may begin the guide
Before beginning detach the ear muff
Use the Metal Spudger to help detach
Highlighted in the red circle is what needs to be detached in order to start the guide
Everything will be located on the left side of The Ozeino OW810
After detaching the ear muff gather your tools
You will need The Marlin Screw Driver set
Take The Phillips #0 screwdriver to begin
Highlighted in red is the first screw needed to remove
Use Phillips #0 to unscrew
Highlighted is the second screw needed to be removed
Use Phillips #0 screwdriver
Highlighted is the third screw needed to be removed
Use Phillips #0
Highlighted is the fourth screw needed to be removed
Highlighted is the fifth screw needed to be removed
Highlighted is the last screw needed to be removed
You should have unscrewed 6 screws from the ear muff
After unscrewing the screws from the ear muff remove the piece
Locate circuit board highlighted
Highlighted are the screws needed to be removed from the circuit board
Remove the motherboard from the headset.
Remove both earmuff pieces
Unscrew all 5 3.175mm screws from each side of the ear pieces
Pull sound pieces (that go towards the ear) off both sides of the headset
Pry the silver battery off of the frame
Carefully unscrew the 2mm screw on the green circuit board
Pull circuit board out carefully
Once circuit board is removed, unscrew the four screws on the frame beneath it
Repeat on other side
Remove the light board portion from the back of the earpiece
Remove 3.174mm screws from the white framing
Remove the 2 4mm screws in the black piece of the headband
Gently pull on the earpiece framing to remove it from the headband
Carefully remove and replace the cushioning
