The buttons may get stuck or broken with use. This guide will show how to remove the buttons in order to properly replace them.
Remove the bread pan.
Remove the eight 22mm Phillips #1 screws from the grey lining.
Remove the grey liner.
Remove the two 11mm Phillips #1 screws from the back of the device.
Pop off the top case using a spudger.
Disconnect microcontroller and top lining.
Remove the two 11mm Phillips #1 screws from the top cover.
Use spudger to pop the control panel out.
Remove the four 11mm Phillips #1 screws from the control panel.
Remove the two 11mm Phillips #1 screws from the button panel.
Flip the screen assembly over and remove the button panel.
Remove and replace buttons as necessary.
This was a great set of instructions. However, I can't find any source for replacement buttons (or the button panel, since that's what appears to have failed on my unit).
So taking it apart was fun, but futile
