Remove the lid, steamer pot, and tray from the base unit.
Flip the base unit over.
Remove the two Phillips screws.
Remove the bottom cover.
Remove the three Phillips screws
Remove the fuse from the unit.
Flip the unit over.
Flip the unit back over.
Remove the single Phillips Screw.
Bend the tabs inward with needle nose pliers to mirror the shape of the hole below it.
Lift the lever out of the tab.
Carefully pull the front panel and lever out the front of the base.
Remove the Phillips screw.
Carefully remove the circuit board from the front panel.
Remove the nut using an adjustable wrench.
Remove the power connector extender.
Remove the three Phillips Screws.
This screw is slightly longer than the other two.
Bend the three tabs flat.
Remove the thermomagnet assembly from the heating coil.
