Use this guide to replace your damaged Blade Assembly.
Grip the blender base with one hand and blender bottle with the other hand.
Rotate the blender bottle a quarter turn counterclockwise .
Lift the blender bottle out of the blender base. The blade assembly should still be attached to the blender bottle.
Grip the blade assembly with one hand and blender bottle with the other hand.
Rotate the blade assembly counterclockwise until it is completely unscrewed from the blender bottle.
Lift the blender bottle to separate it from the blade assembly.
After removing the blade assembly from the blender bottle, ensure your blade assembly has its seal placed in the seal bed.
I’m confused, these are the steps you have to go through every single time you use this blender to blend something. This isn’t really a “replacement” process here. If someone needs to repair a cracked blade assembly or buy a new one, how would they do that?
This process is not helpful at all. I followed as instructed but the blade is not moving at all?! What is going on? Pls provide better HELP INSTRUCTIONS.
