Oster 6329 Outer Shell Removal
  1. Oster 6329 Outer Shell Removal, Outer Shell Removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Oster 6329 Outer Shell Removal, Outer Shell Removal: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the Phillips-head #2 screwdriver, unscrew the three 1cm Phillips-head screws on the plastic base of the toaster to separate the outer metal shell from the plastic base.
  2. Oster 6329 Outer Shell Removal: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the plastic push-down handle down and pull the plastic handle straight from metal arm.
  3. Oster 6329 Outer Shell Removal: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen the outer metal shell from the plastic base by holding the plastic base while pulling up on the metal shell.
    • Only lift the outer shell a little so as not to disconnect the cables that connect the circuit board.
  4. Oster 6329 Outer Shell Removal: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Oster 6329 Outer Shell Removal: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the cable clips from the circuit board using the tweezers to free the outer metal shell from the plastic base.
  5. Oster 6329 Outer Shell Removal: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Oster 6329 Outer Shell Removal: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the top outer metal shell.
    • Carefully lift the outer metal shell at an angle so as not to damage the components in the front of the toaster.
Isaac Williams
crwdns2935283:001/24/14crwdne2935283:0
225 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 13-15, Regan Winter 2014 crwdns2935289:0Cal Poly, Team 13-15, Regan Winter 2014crwdne2935289:0
CPSU-REGAN-W14S13G15
crwdns2942667:0crwdne2942667:0 2,254
