Oster 3905 Lever Spring Replacement
  1. Oster 3905 Lever Spring Replacement, Slot Levers: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Firmly grip your hand around the slot lever.
  2. Oster 3905 Lever Spring Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Stabilize the toaster by placing your hand on top.
  3. Oster 3905 Lever Spring Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Oster 3905 Lever Spring Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Forcefully pull the slot lever away from the toaster by keeping parallel to the table.
  4. Oster 3905 Lever Spring Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Both slot levers can be removed.
  5. Oster 3905 Lever Spring Replacement, Outer Shell: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the toaster upside down so the bottom is facing the ceiling.
  6. Oster 3905 Lever Spring Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Oster 3905 Lever Spring Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Take off both rubber feet using a small metal spudger.
    • Wedge a spudger under the feet and pull up to pop off.
  7. Oster 3905 Lever Spring Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a PH#2 screw bit to remove eight 12mm screws that are located around the perimeter.
    • There are two screws under the rubber feet.
  8. Oster 3905 Lever Spring Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the toaster right side up.
  9. Oster 3905 Lever Spring Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Oster 3905 Lever Spring Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the outer shell firmly and pull up towards the face of the toaster.
  10. Oster 3905 Lever Spring Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • For this part, you might need to wiggle the toaster to get the outer shell off.
    • The shell will not completely come off until the motherboard is removed in the next step.
  11. Oster 3905 Lever Spring Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Oster 3905 Lever Spring Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Oster 3905 Lever Spring Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a J1 screw bit to unscrew eight 8mm screws from the motherboard.
  12. Oster 3905 Lever Spring Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Oster 3905 Lever Spring Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Take out the grey “cancel” and “bagel” buttons from the shell.
  13. Oster 3905 Lever Spring Replacement, Lever Spring: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Oster 3905 Lever Spring Replacement, Lever Spring: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the plastic opening tool to remove the top metal panel by prying the 4 top metal tabs upwards. They will be able to slide through the openings and be pulled upwards.
  14. Oster 3905 Lever Spring Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Oster 3905 Lever Spring Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the top metal panel is unhooked, lift and let it hang off the side of the toaster.
  15. Oster 3905 Lever Spring Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Oster 3905 Lever Spring Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Oster 3905 Lever Spring Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a metal spudger to pry the 8 tabs upwards along the metal that separates the two slots.
    • Pull the metal spacer upwards to release from the toaster.
  16. Oster 3905 Lever Spring Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Oster 3905 Lever Spring Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the spring wrapped around a metal rod at the front of the toaster, located behind the white plastic lever holder.
Sydney Alcaraz
crwdns2935283:009/12/16crwdne2935283:0
601 crwdns2915208:0crwdne2915208:0
CSU Fullerton, Team 2-1, Bruce Fall 2016 crwdns2935289:0CSU Fullerton, Team 2-1, Bruce Fall 2016crwdne2935289:0
CSUF-BRUCE-F16S2G1
Yeah. You just remove the spring? And then what? Surely removing the spring is not the fix.
kryshu - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,178
