Oster 16-Speed Blender Power Cord Replacement
  1. Oster 16-Speed Blender Power Cord Replacement, Fan and Motor: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Oster 16-Speed Blender Power Cord Replacement, Fan and Motor: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the Blender Container from the Blender Base.
  2. Oster 16-Speed Blender Power Cord Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Oster 16-Speed Blender Power Cord Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the blender so the bottom is facing you.
  3. Oster 16-Speed Blender Power Cord Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Oster 16-Speed Blender Power Cord Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Oster 16-Speed Blender Power Cord Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the 16mm screws located on the plastic bottom from the blender base using a Phillips #2 screwdriver.
  4. Oster 16-Speed Blender Power Cord Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Oster 16-Speed Blender Power Cord Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the plastic bottom from the base of the blender.
  5. Oster 16-Speed Blender Power Cord Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Oster 16-Speed Blender Power Cord Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Holding the center of the fan, grip the knob in the center of the top of the blender with a wrench and twist the wrench counterclockwise.
  6. Oster 16-Speed Blender Power Cord Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the motor and fan from the base of the blender.
  7. Oster 16-Speed Blender Power Cord Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Oster 16-Speed Blender Power Cord Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Oster 16-Speed Blender Power Cord Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Now, gently pull the white wire that is connected to the base and the motor.
    • Be careful, as there is a spring behind the contact points, that might try to shoot out and hurt you.
  8. Oster 16-Speed Blender Power Cord Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Oster 16-Speed Blender Power Cord Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Oster 16-Speed Blender Power Cord Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Now, turn the motor over, and remove the black wire from the motor.
    • Again, be warned as the is another spring that wants to shoot out and hurt you here as well.
  9. Oster 16-Speed Blender Power Cord Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Oster 16-Speed Blender Power Cord Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now de-solder the yellow wire from circuit board. De-solder the wire following these instructions.
    • Be careful, as there is another, black wire, nearby that you do not want to de-solder.
  10. Oster 16-Speed Blender Power Cord Replacement, Circuit Board: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Oster 16-Speed Blender Power Cord Replacement, Circuit Board: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Oster 16-Speed Blender Power Cord Replacement, Circuit Board: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the four 11mm screws in the circuit board.
    • Unscrew the four screws using the Phillips #1 screwdriver.
  11. Oster 16-Speed Blender Power Cord Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Oster 16-Speed Blender Power Cord Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Desolder the circuit board from the base at the indicated point, following the directions by clicking here.
    • Now separate the circuit board from the base.
  12. Oster 16-Speed Blender Power Cord Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Oster 16-Speed Blender Power Cord Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Oster 16-Speed Blender Power Cord Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • You will see that the circuit board is still attached by a red wire and a black wire.
    • Flip the circuit board back over and desolder at the indicated points following the directions given here.
  13. Oster 16-Speed Blender Power Cord Replacement, Power Cord: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You do not have to completely remove the circuit board to replace the power cord. You can, if desired, skip the steps of de-soldering the yellow wire, and the circuit board from the base.
    • De-solder the black wire from the circuit board, and then carefully remove the black wire.
    • Now you can solder on the new power cord.
Dana
crwdns2935283:004/14/14crwdne2935283:0
818 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 12-37, Maness Spring 2014 crwdns2935289:0Cal Poly, Team 12-37, Maness Spring 2014crwdne2935289:0
CPSU-MANESS-S14S12G37
crwdns2942667:0crwdne2942667:0 3,605
