First, remove the blender container from the Blender Base, by grabbing the handle and lifting up.
Next, remove the lid from the Blender Container.
Flip the container on its side so that the bottom faces you.
Now rotate the bottom counter-clockwise to remove it from the container.
Now you will see the bottom of the blender blades once the bottom piece is removed
With your container separated, it can now be replaced. To reassemble your device, follow these instructions in reverse order.
