Oster 16-Speed Blender Circuit Board Replacement
  1. Oster 16-Speed Blender Circuit Board Replacement, Fan and Motor: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Oster 16-Speed Blender Circuit Board Replacement, Fan and Motor: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the Blender Container from the Blender Base.
  2. Oster 16-Speed Blender Circuit Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Oster 16-Speed Blender Circuit Board Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the blender so the bottom is facing you.
  3. Oster 16-Speed Blender Circuit Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Oster 16-Speed Blender Circuit Board Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Oster 16-Speed Blender Circuit Board Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the 16mm screws located on the plastic bottom from the blender base using a Phillips #2 screwdriver.
    Is it possible to get a replacement base. Just the plastic cover? I can't seem to find mine and it is cracked and broken yet still works.
    Blendin life - crwdns2934203:0crwdne2934203:0
  4. Oster 16-Speed Blender Circuit Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Oster 16-Speed Blender Circuit Board Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the plastic bottom from the base of the blender.
  5. Oster 16-Speed Blender Circuit Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Oster 16-Speed Blender Circuit Board Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Holding the center of the fan, grip the knob in the center of the top of the blender with a wrench and twist the wrench counterclockwise.
  6. Oster 16-Speed Blender Circuit Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the motor and fan from the base of the blender.
  7. Oster 16-Speed Blender Circuit Board Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Oster 16-Speed Blender Circuit Board Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Oster 16-Speed Blender Circuit Board Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Now, gently pull the white wire that is connected to the base and the motor.
    • Be careful, as there is a spring behind the contact points, that might try to shoot out and hurt you.
  8. Oster 16-Speed Blender Circuit Board Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Oster 16-Speed Blender Circuit Board Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Oster 16-Speed Blender Circuit Board Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Now, turn the motor over, and remove the black wire from the motor.
    • Again, be warned as the is another spring that wants to shoot out and hurt you here as well.
  9. Oster 16-Speed Blender Circuit Board Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Oster 16-Speed Blender Circuit Board Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now de-solder the yellow wire from circuit board. De-solder the wire following these instructions.
    • Be careful, as there is another, black wire, nearby that you do not want to de-solder.
    Buenos dias
    Existe un buje de hule que se cayo porque esta deshecho, pero no sé en que parte va. Me pueden orientar.
    Gracias
    Rafael Hernandez Guerrero - crwdns2934203:0crwdne2934203:0
  10. Oster 16-Speed Blender Circuit Board Replacement, Circuit Board: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Oster 16-Speed Blender Circuit Board Replacement, Circuit Board: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Oster 16-Speed Blender Circuit Board Replacement, Circuit Board: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the four 11mm screws in the circuit board.
    • Unscrew the four screws using the Phillips #1 screwdriver.
  11. Oster 16-Speed Blender Circuit Board Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Oster 16-Speed Blender Circuit Board Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Desolder the circuit board from the base at the indicated point, following the directions by clicking here.
    • Now separate the circuit board from the base.
    I need to but this board but can’t find it anywhere. Sigh. Only one button works when i turn on the blender but i’ve opened it several times and have found nothing wrong with it. I’m so confused.
    dbagarotti - crwdns2934203:0crwdne2934203:0
  12. Oster 16-Speed Blender Circuit Board Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Oster 16-Speed Blender Circuit Board Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Oster 16-Speed Blender Circuit Board Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • You will see that the circuit board is still attached by a red wire and a black wire.
    • Flip the circuit board back over and desolder at the indicated points following the directions given here.
    buenas tardes, tengo una pregunta, para soldar, involuntariamente, dejé los platos y ahora no los escucho para acomodarlos, podría ayudar en la secuencia, ¡muchas gracias!
    missymirikity D - crwdns2934203:0crwdne2934203:0
    Hola. Me ayuda? Mi circuit board le faltan dos de esos circulitos blancos que se ven adentro. Eso affecta en algo. El problema es que solamente un boton sirve..
    Things Happen -
    good afternoon, I have a question, to be welding, unintentionally, the cards went out and now I do not know the order to accommodate them, they could help me in the sequence, thank you very much !!!
    Only one button works on mine and i just don’t see anything wrong with it. What could be the issue? What about if i want to buy a new circuit board, do you guys sell it?
Now your circuit board is ready to be replaced. To reassemble your device, follow these instructions in reverse order.
Dana
crwdns2935283:004/14/14crwdne2935283:0
818 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 12-37, Maness Spring 2014 crwdns2935289:0Cal Poly, Team 12-37, Maness Spring 2014crwdne2935289:0
CPSU-MANESS-S14S12G37
crwdns2947412:010crwdne2947412:0
So, a question. Where does the spring go? I was fixing one of these and the spring fell out and I never saw where it came from.
Seth Grady - crwdns2934203:0crwdne2934203:0
inside 2 tubes that stick out opposite of each other just below the fan.
dbagarotti -
Spring goes on the one of the strips that slides back and forth....it has small end which goes in a small notched cavity of the plastic housing. Spring goes on that longer end of the stripe. See the picture in step 12...its popped out from the plastic housing.
Jignesh Rathod -
conoces el orden de las laminas del circuito de velocidades…? agradecere cualquier sugerencia…
juliogpe_cc - crwdns2934203:0crwdne2934203:0
Awesome, this guide was really helpful in repairing my blender. Thumbs up for the author.
Okikiolu Jegede - crwdns2934203:0crwdne2934203:0
Thanks for this very helpful guide with the great photos! I repaired my blender (same model; some of the speed buttons weren’t working) WITHOUT needing to search the world for replacement parts. (I never did find a new motor or circuit board; only refurbs on ebay). Maybe I was lucky, but this is what worked for me:
STEP 11: Look at ALL the solder points on the circuit board. If any look dull or cracked, re-solder them all carefully. This might be all that’s gone wrong. But go on to Step 12 before assembling & testing the blender:
STEP 12: Clean all the copper contacts on the bottom side of circuit board and where it fits onto the base. I used CRC electronic spray cleaner and a Q-tip (rub gently). Also check the glass fuse near those contacts!
Now re-assemble and test. I hope your blender now works without needing a new circuit board. Good luck!
katwyn - crwdns2934203:0crwdne2934203:0
Hi, where can I buy circuit board for blenders ?
steph74 - crwdns2934203:0crwdne2934203:0
Agree with the last comment from KATWYN. I didn't want to buy refurbished board, in addition to the steps s/he mentioned, I applied die-electric grease on each copper "fingers" which arc when making / breaking the contact deteriorating over time. My problem was the low / high speed switch which i cleaned with connector cleaner. Don't use harsh solvent as plastic parts can get dissolved, affecting free movements of the switch.
Jignesh Rathod - crwdns2934203:0crwdne2934203:0
Conoce el orden de las laminas del circuito de velocidades…? agradeceré cualquier sugerencia. Gracias
nelson ramirez - crwdns2934203:0crwdne2934203:0
Conoces el orden de las laminas del circuito de velocidades…? agradeceré cualquier sugerencia. Gracias
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 82
crwdns2942667:0crwdne2942667:0 6,456
