Osram Lightify Disassembly
  1. Osram Lightify Disassembly, Osram: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the front using a metal spudger.
    • Once you can get your fingers in, remove the rest using your hand.
  2. Osram Lightify Disassembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Osram Lightify Disassembly: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On the back of the front cover, remove the white plastic using a metal spudger.
    • Remove the PCB using a spudger
  3. Osram Lightify Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Osram Lightify Disassembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the PCB is removed, use a Torx T9 screwdriver to unscrew and remove the power supply.
    • Remove the screws holding on the back cover with a Torx T9 screwdriver and remove the back cover.
    • all the screws are the same. they can be mixed with no problem.
  4. Osram Lightify Disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Osram Lightify Disassembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Osram Lightify Disassembly: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the button by grabbing the tab over the button and pulling it out.
    • it will not come out if the button is not depressed.
    • Remove both metal sheets. when its at an angle, push it in a little and then pull it up so that it is pointing straight up. then, you can push it through.
Aiden
crwdns2935283:009/19/15crwdne2935283:0
17,867 crwdns2915208:0crwdne2915208:0
crwdns2935297:021crwdne2935297:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 285
