Osmo Mobile Trigger Button Replacement
William Tyler Wills
crwdns2944107:0crwdnd2944107:0William Tyler Willscrwdnd2944107:0crwdnd2944107:0crwdnd2944107:04crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Mud 7, 2024crwdne2944111:0
crwdns2931287:025crwdne2931287:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
The trigger button is the one of the most used buttons on the DJI Osmo Mobile, and this guide will serve to teach the device owner how to replace a broken or unresponsive trigger button.
crwdns2944105:0crwdne2944105:0
  1. Osmo Mobile Trigger Button Replacement, Osmo Mobile Handle Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Osmo Mobile Trigger Button Replacement, Osmo Mobile Handle Disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove gimbal from base handle by loosening round plate found at the top of the handle.
    This step isn't clear. How is the ring removed? Twist? Pry?
    Jo Dee Lee - crwdns2934203:0crwdne2934203:0
    Same question for me
    Guitt97ii -
    Tried for hours. Seems it’s glued on?
    ok, the top cap is screwed on. I used a double sided tape around it to have a better grip and just twisted it. The cap has thread lock in it.
    You passed this step?
    Guitt97ii -
    U passed this step???
    Guitt97ii -
  2. Osmo Mobile Trigger Button Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Osmo Mobile Trigger Button Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use Phillips #00 screwdriver to remove the three screws found on the gimbal stabilizer to detach handle from gimbal.
    • Carefully detach handle from gimbal and disconnect the cable that connects the two.
  3. Osmo Mobile Trigger Button Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the hex screws found at the top base of the handle, and unscrew using the 1.5mm hex screwdriver.
  4. Osmo Mobile Trigger Button Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Osmo Mobile Trigger Button Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove joystick by gently pulling away from handle
  5. Osmo Mobile Trigger Button Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Osmo Mobile Trigger Button Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Osmo Mobile Trigger Button Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the quick release PCBA by locating the connecting wires and release the ribbon cable with tweezers.
    • Use the spudger to pry open and remove the face plate, starting at the back of the handle.
  6. Osmo Mobile Trigger Button Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Osmo Mobile Trigger Button Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Osmo Mobile Trigger Button Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate four screws directly on top of handle.
    • Unscrew the silver, bottom two screws, that are closest to the face plate using the 00 screwdriver.
    • Unscrew the black, top two screws, located furthest from the face plate, using the 0 screwdriver.
    • Remove the remaining two screws found on the front of the faceplate.
    • Remove the rest of the face plate shell.
    hola alguien sabe donde puedo adquirir la face plate shell de refaccion?
    gracias
    jose - crwdns2934203:0crwdne2934203:0
    I know. - Nowhere. You need buy another gimbal (non-working) for a parts. By the way, it will be good to make a manual for other disassembling of a gimbal - I mean rotating parts. Some info of this can be found in this video on Youtube: https://www.youtube.com/watch?v=-5Xi-b8s...
    But not too much :(
    nik_gmp - crwdns2934203:0crwdne2934203:0
  7. Osmo Mobile Trigger Button Replacement, Charging Port: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the top left screw on the joystick panel with Phillips #00 screwdriver.
    • Lift faceplate holding joystick module.
  8. Osmo Mobile Trigger Button Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bottom right screw on the joystick panel with the #00 Phillips screwdriver.
  9. Osmo Mobile Trigger Button Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Hold down the larger of the two ribbon cables, and pull on circuit board with a constant and careful down and out motion.
  10. Osmo Mobile Trigger Button Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws from the green charging module and the two screws on the grey plate and remove from handle.
    • Replace charging module.
  11. Osmo Mobile Trigger Button Replacement, Trigger Button: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Osmo Mobile Trigger Button Replacement, Trigger Button: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tweezers to push outward on the backside of the trigger button hinges.
    • Pop out trigger button.
  12. Osmo Mobile Trigger Button Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the tweezers to remove the underlying button that contacts with the trigger button, and replace.
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
William Tyler Wills
crwdns2935283:009/28/17crwdne2935283:0
429 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S2-G1, Nance Fall 2017 crwdns2935289:0USF Tampa, Team S2-G1, Nance Fall 2017crwdne2935289:0
USFT-NANCE-F17S2G1
How I can fix the USB port, it went inside the handle?
Juan Carlos Beltran - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 2,760
