Osmo Mobile Handle Disassembly
  1. Osmo Mobile Handle Disassembly, Osmo Mobile Handle Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Osmo Mobile Handle Disassembly, Osmo Mobile Handle Disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove gimbal from base handle by loosening round plate found at the top of the handle.
  2. Osmo Mobile Handle Disassembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Osmo Mobile Handle Disassembly: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use Phillips #00 screwdriver to remove the three screws found on the gimbal stabilizer to detach handle from gimbal.
    • Carefully detach handle from gimbal and disconnect the cable that connects the two.
  3. Osmo Mobile Handle Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the hex screws found at the top base of the handle, and unscrew using the 1.5mm hex screwdriver.
  4. Osmo Mobile Handle Disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Osmo Mobile Handle Disassembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove joystick by gently pulling away from handle
  5. Osmo Mobile Handle Disassembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Osmo Mobile Handle Disassembly: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Osmo Mobile Handle Disassembly: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the quick release PCBA by locating the connecting wires and release the ribbon cable with tweezers.
    • Use the spudger to pry open and remove the face plate, starting at the back of the handle.
  6. Osmo Mobile Handle Disassembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Osmo Mobile Handle Disassembly: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Osmo Mobile Handle Disassembly: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate four screws directly on top of handle.
    • Unscrew the silver, bottom two screws, that are closest to the face plate using the 00 screwdriver.
    • Unscrew the black, top two screws, located furthest from the face plate, using the 0 screwdriver.
    • Remove the remaining two screws found on the front of the faceplate.
    • Remove the rest of the face plate shell.
Ustena Safa
crwdns2935283:009/28/17crwdne2935283:0
363 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S2-G1, Nance Fall 2017 crwdns2935289:0USF Tampa, Team S2-G1, Nance Fall 2017crwdne2935289:0
USFT-NANCE-F17S2G1
crwdns2947412:010crwdne2947412:0
Bonjour,
La toute première étape est trop vague pouvez-vous donner plus de détails svp.
Je vous remercie d’avance
Guitt97ii - crwdns2934203:0crwdne2934203:0
I would not call that a handle disassembly. This instruction takes you up to the things you need to do PRIOR to disassembly.
I can show you the rest in a video format if you’re interested
John M O'Donovan - crwdns2934203:0crwdne2934203:0
Could you please show me how to fix the USB port that wenr inside the handle? on my Smove gimbal stabilizer
Juan Carlos Beltran -
My osmo has snapped off at the metal camera attachment. Can this be repaired ?
michelle Moore - crwdns2934203:0crwdne2934203:0
Your help would be greatly appreciated
Emile Jansen -
crwdns2936753:030crwdne2936753:0 131
crwdns2942667:0crwdne2942667:0 9,399
