Oregon Scientific RM318PA Lens Replacement
  1. Oregon Scientific RM318PA Lens Replacement, A/C Adapter: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Oregon Scientific RM318PA Lens Replacement, A/C Adapter: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Oregon Scientific RM318PA Lens Replacement, A/C Adapter: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Hold clock so the screen is facing away from you.
    • Using your thumbs, push up on battery cover to remove.
    • With your other hand, pull down on the A/C Adapter jack to remove.
  2. Oregon Scientific RM318PA Lens Replacement, Batteries: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove batteries by pushing a battery toward the spring.
    • Lift battery out at an angle. Repeat with second battery.
  3. Oregon Scientific RM318PA Lens Replacement, Projection Arm: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Oregon Scientific RM318PA Lens Replacement, Projection Arm: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #00 Screwdriver to remove the four (4) screws from the back of the projection arm.
    • Once screws are removed, lift the back up and off of the projection arm.
  4. Oregon Scientific RM318PA Lens Replacement, Screws Projection Arm: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Oregon Scientific RM318PA Lens Replacement, Screws Projection Arm: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #00 Screwdriver to remove two (2) screws from back of projection arm.
  5. Oregon Scientific RM318PA Lens Replacement, Front of the Projection Arm: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Oregon Scientific RM318PA Lens Replacement, Front of the Projection Arm: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Plastic Opening Tool to pry open the front of the projection arm casing. Start at the top of the projection arm.
    • Once top is partially open, use a Spudger to pry at the side of the projection arm.
  6. Oregon Scientific RM318PA Lens Replacement, Projection Beam: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Oregon Scientific RM318PA Lens Replacement, Projection Beam: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Oregon Scientific RM318PA Lens Replacement, Projection Beam: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the clock on its side. Slide the focus wheel forward with your thumb.
    • The Projection Beam and Focus Wheel Component should now be free of Projection Arm.
    • Hold the Component in one hand and lift the Projection Beam up and away from the Focus Wheel.
  7. Oregon Scientific RM318PA Lens Replacement, The Lens: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The Lens is attached to the Focus Knob and is now accessible for replacement purposes.
  8. Oregon Scientific RM318PA Lens Replacement, Tape: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply tape to the lens for safe removal and prevention of injury.
  9. Oregon Scientific RM318PA Lens Replacement, Focus Knob: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Oregon Scientific RM318PA Lens Replacement, Focus Knob: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Detach the focus knob from the internal casing of the lens by removing the screw from the base of the focus knob grip.
    • Pry apart the pieces of casing holding the focus knob in place and remove the knob.
  10. Oregon Scientific RM318PA Lens Replacement, Internal Casing: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Oregon Scientific RM318PA Lens Replacement, Internal Casing: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Oregon Scientific RM318PA Lens Replacement, Internal Casing: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the spudger into the opening above the hinge on the side of the casing.
    • Press down firmly until the case opens.
  11. Oregon Scientific RM318PA Lens Replacement, Lens Removal: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Oregon Scientific RM318PA Lens Replacement, Lens Removal: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull apart the casing and gently slide lens from pocket.
    • Be sure to replace with a concave lens.
Maxine Holden
crwdns2935283:010/27/14crwdne2935283:0
482 crwdns2915208:0crwdne2915208:0
Hi, I’ve this alarm clock with missing piezo/speaker, can anyone take a picture of the main board showing the pads for it?
Mastto geppetto - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 2,649
