By following the steps below, you will be able to remove and replace the speakers of your Oregon Scientific Meep! 4.0.
Use a screwdriver to remove the four 7.0 mm Philips #00 screws from the back of the device.
Use a plastic opening tool to detach the clips on the inside of the device.
Remove the electric tape holding the wires of the speakers in place and gently pull the speakers out of their slots in the device.
Use a soldering station to separate the wires from the speakers.
