By following the steps in this guide in order, you will be able to remove and replace the broken motherboard of your Oregon Scientific Meep! 4.0 tablet.
Use a screwdriver to remove the four 7.0 mm Philips #00 screws from the back of the device.
Use a plastic opening tool to detach the clips on the inside of the device.
Use a soldering station to disconnect any wires attached to the motherboard.
Use a screwdriver to unscrew the three 4.0 mm Philips #00 screws holding the motherboard in place.
Use a plastic opening tool to release the ribbon cables surrounding the motherboard.
