Using this guide, you will be able to open your Oregon Scientific Meep! and remove your faulty battery, which can be replaced with a new one.
Use a screwdriver to remove the four 7.0 mm Philips #00 screws from the back of the device.
Use a plastic opening tool to detach the clips on the inside of the device.
Remove the black tape holding the battery in place.
Use a spudger to separate the battery from its adhesive.
Use a soldering station to separate the battery from its connecting wires.
