Oregon Scientific BAR339DP Light Projector Repurpose
  1. Oregon Scientific BAR339DP Light Projector Repurpose, Light Projector Conversion: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Instead of showing the clock/weather in the projection, you'll end up to see a large red disc.
    • This is going to REPLACE the existing functionality and is most likely not undoable.
    • Proceed at your own risk!
  2. Oregon Scientific BAR339DP Light Projector Repurpose, Remove the housing: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Oregon Scientific BAR339DP Light Projector Repurpose, Remove the housing: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Oregon Scientific BAR339DP Light Projector Repurpose, Remove the housing: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently pry open the front case of the projector module.
    • Undo the 6 screws using a small Phillips screwdriver and remove the cover.
    • Pull on the projection assembly to detach it from the case. The top part, containing the lens is detachable by hand, the bottom one has 3 clips and a nut that secures it.
  3. Oregon Scientific BAR339DP Light Projector Repurpose, Disassemble the projector unit: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Oregon Scientific BAR339DP Light Projector Repurpose, Disassemble the projector unit: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Oregon Scientific BAR339DP Light Projector Repurpose, Disassemble the projector unit: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a flat screwdriver/pryer press on the tabs on both sides of the assembly to make them loose.
    • Gently press on the upper piece of plastic, to the top.
    • Unscrew the large nut.
  4. Oregon Scientific BAR339DP Light Projector Repurpose, Decision time: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Oregon Scientific BAR339DP Light Projector Repurpose, Decision time: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Oregon Scientific BAR339DP Light Projector Repurpose, Decision time: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After you disassemble the projector case, you can see the projector light, the passthrough display and the board that powers it.
    • You have 2 options:
    • Try to remove the connecting flex cable between the display and the board and replace it/repair it or clean the contacts on both ends. [I have tried this without success as the wires ripped off because they were aged]
    • Remove the display from the position (with or without removing the flex cable) and allow the projecting light to go through the lens directly - this way you obtain a big round red light: Mars on your wall!
  5. Oregon Scientific BAR339DP Light Projector Repurpose: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Oregon Scientific BAR339DP Light Projector Repurpose: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The red light is very bright, now it's time to reassemble the device in the reverse order!
    • In case you decided to remove the LCD screen, you should end up with a projection as seen in the picture taken in a dark room.
    • Enjoy your new ceiling light!
bmdbest
crwdns2935283:012/08/16crwdne2935283:0
593 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 435
