Ordro HDV-D395 Lens Replacement
  1. Ordro HDV-D395 Lens Replacement, Lens: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ordro HDV-D395 Lens Replacement, Lens: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the slider labeled open, on the bottom right, to unlock the battery.
  2. Ordro HDV-D395 Lens Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull battery out of slot.
  3. Ordro HDV-D395 Lens Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three screws (length 7.7 mm) from the bottom of the outer case using a JIS000 screwdriver.
  4. Ordro HDV-D395 Lens Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ordro HDV-D395 Lens Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove plastic casing hiding screws from the strap side of the casing.
    • Unscrew the three screws (length 4.75 mm) using a PH000 screwdriver.
    • Unscrew the two screws (length 6.4 mm) using a JIS000 screwdriver.
  5. Ordro HDV-D395 Lens Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the four screws (2.9 mm length) from the screen side of the casing using a JIS000 screwdriver.
  6. Ordro HDV-D395 Lens Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove both side casings by gripping the sides with your hands and pulling gently.
  7. Ordro HDV-D395 Lens Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ordro HDV-D395 Lens Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ordro HDV-D395 Lens Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Although it requires extra steps, it is advised that you remove the motherboard and screen to ensure that nothing is damaged in the process of replacing the lens.
    • Unscrew the seven screws (length 4.22 mm) from the motherboard using a PH000 screwdriver.
    • Pull out or desolder all connected cords from motherboard.
  8. Ordro HDV-D395 Lens Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ordro HDV-D395 Lens Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove top of the casing to reveal the screws on lens.
    • Unscrew the four screws (size 4.90 mm) using a PH00 screwdriver.
  9. Ordro HDV-D395 Lens Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ordro HDV-D395 Lens Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ordro HDV-D395 Lens Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull out lens.
    • Remove cord from lens.
Nathan Mcintyre
crwdns2935283:011/05/18crwdne2935283:0
303 crwdns2915208:0crwdne2915208:0
IUPUI, Team S1-G3, Baechle Fall 2018 crwdns2935289:0IUPUI, Team S1-G3, Baechle Fall 2018crwdne2935289:0
IUPUI-BAECHLE-F18S1G3
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 270
